Ir para o conteúdo principal
Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement
Garrett barta
Garrett barta e um outro colaborador
Última atualização em June 16, 2019
Nenhuma estimativa
Muito fácil
Faltando detalhes
A guide to replace the SUB/SD card/headphone jack within your Toshiba Radius.
O que você precisa
Ferramentas
  1. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 2, imagem 1 %32
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 3, imagem 1 %32
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 4, imagem 1 %32
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, USB/SD/headphone jack: passo 5, imagem 1 %32
    • Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
  6. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 6, imagem 1 %32
    • disconnect the cable shown from the motherboard
  7. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 7, imagem 1 %32
    • disconnect the cable attached to the top of the USB/SD card/headphone jack interface
  8. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 8, imagem 1 %32
    • remove the interface
Conclusão
Garrett barta
Membro desde: 09/20/17
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 409
