Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
Introdução
Ir para o passo 1The motherboard of your device acts as a meeting point for crucial components, such as the CPU and input and output devices. To replace a damaged or defective motherboard, you will remove all connected peripherals, replace the motherboard, and reconnect all peripherals.
O que você precisa
Peças
Ferramentas
Exibir mais…
Using the plastic opening tool, remove the two rubber feet closest to the hinge.
