Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement
Introdução
Vá para o passo 1This guide will allow you to replace your Toshiba Satellite's wireless connection card.
O que você precisa
Ferramentas
Exibir mais…
Unplug your laptop from any source of power.
Lay your laptop on a soft, clean surface as shown.
Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
Loosen the three non-hinge edges.
Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
Remove the tape partially covering the wireless card. It may be helpful to do this using a plastic opening tool.
