Introdução
This guide will explain how to replace the screen on the Toshiba Satellite P855-S5312. Reasons for replacement include black or spotty screen images. The screen is a very fragile component of the device. It requires a small plastic prying tool and a small screwdriver.
O que você precisa
Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
Pry up the panel to gain access to hidden screws.
Turn laptop upside down with the spine facing towards you and locate the microchip.
Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
Uma outra pessoa concluiu este guia.
