Ir para o conteúdo principal
Toshiba Satellite P55t-A5116 Battery Replacement
Brittany Castillo
Brittany Castillo e 4 outros colaboradores
Última atualização em October 21, 2022
2 minutos
Moderada
Use this guide to remove the Toshiba Satellite P55t-A5116 battery.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: passo 1, imagem 1 %32 Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55t-A5116 Battery Replacement: passo 2, imagem 2 %32
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, imagem 3 %32
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Battery Replacement, Battery: passo 4, imagem 1 %32 Toshiba Satellite P55t-A5116 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Battery Replacement: passo 5, imagem 1 %32
    • Gently remove battery from the laptop.
Conclusão
12 outras pessoas executaram este guia.
9 comentários
The screws for the battery are in very tight and I'm having trouble unscrewing them
Brianna Brucale - Responder
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
jmomenee - Responder
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
Carmen Cuevas -
I did all of that but my laptop didn’t reboot, any suggestions
roberta - Responder
I had no problem installing the new battery, but even after letting it charge over 24 hours. Not able to get it to turn on
roberta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 34
Duração total: 23,022
