Ir para o conteúdo principal
Toshiba Satellite P55W-C5316 Screen Replacement
Kyle Dierking
Kyle Dierking e 4 outros colaboradores
Última atualização em March 29, 2023
20 - 25 minutos
Moderada
Precisa de melhores imagens
Precisa de mais images
Faltando Passos
The screen is a component that is susceptible to extensive damage. In addition, the screen is the one of the most common components that is replaced. If your screen is cracked or if the images aren’t properly displaying on your laptop, follow these instructions to remove the screen in your laptop.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: passo 1, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, imagem 2 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, imagem 3 %32
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Screen Replacement, Fan: passo 3, imagem 1 %32
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Screen Replacement: passo 4, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 4, imagem 2 %32
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, imagem 2 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, imagem 3 %32
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
  6. Toshiba Satellite P55W-C5316 Screen Replacement, Screen: passo 6, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement, Screen: passo 6, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the two screws securing the silver USB protector located on the far right side of the laptop, and pry off the protector.
    • Remove the three screws at the top end of the USB protector using the Phillips #00 screwdriver.
  7. Toshiba Satellite P55W-C5316 Screen Replacement: passo 7, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the screws on metal hinge securing the screen to the laptop.
    • There was only a single screw at the time of guide creation but you should remove any screws from the hinge.
  8. Toshiba Satellite P55W-C5316 Screen Replacement: passo 8, imagem 1 %32
    • Repeat the previous step to remove the screws on the other hinge securing the display to the device.
  9. Toshiba Satellite P55W-C5316 Screen Replacement: passo 9, imagem 1 %32 Toshiba Satellite P55W-C5316 Screen Replacement: passo 9, imagem 2 %32
    • Remove all of the black tape securing the hinge to the laptop.
  10. Toshiba Satellite P55W-C5316 Screen Replacement: passo 10, imagem 1 %32
    • Disconnect the connector directly above the IO cable.
  11. Toshiba Satellite P55W-C5316 Screen Replacement: passo 11, imagem 1 %32
    • Remove the display assembly from the device.
Conclusão
Kyle Dierking
Membro desde: 11/07/19
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G1, Harley Fall 2019 Membro de IUPUI, Team S2-G1, Harley Fall 2019
IUPUI-HARLEY-F19S2G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 706
