Ir para o conteúdo principal
Toshiba Satellite P55W-C5316 RAM Replacement
O que você precisa
  1. Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: passo 1, imagem 1 %32 Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: passo 1, imagem 2 %32
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55W-C5316 RAM Replacement: passo 2, imagem 2 %32 Toshiba Satellite P55W-C5316 RAM Replacement: passo 2, imagem 3 %32
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 RAM Replacement, Battery: passo 3, imagem 1 %32 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: passo 3, imagem 2 %32 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: passo 3, imagem 3 %32
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite P55W-C5316 RAM Replacement: passo 4, imagem 2 %32
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
  5. Toshiba Satellite P55W-C5316 RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: passo 5, imagem 2 %32 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: passo 5, imagem 3 %32
    • Lift up the flap to expose the RAM chip.
    • Un-clip the RAM by pulling the metal clips away from the chip on both sides.
    • Lift the RAM up from the laptop and pull it away from the connector.
Conclusão
Alec Bonnell
Membro desde: 10/18/17
497 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 596
