Toshiba Satellite L675D-S7016 Hard Drive Replacement
Introdução
Ir para o passo 1After going through the Troubleshooting guide, and you hear that your laptop is "clicky" or that the hard drive is not connect, this guide will guide you through the removal of the hard drive.
O que você precisa
Ferramentas
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
To install a new Hard Drive, follow these instructions in reverse order.
