Toshiba Satellite L455-S5046 Keyboard Replacement
5 minutos
Fácil
Introdução
Ir para o passo 1In this guide we will teach you how to replace the keyboard of your laptop.
O que você precisa
Ferramentas
Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
Quase terminado!
Conclusão
