Ir para o conteúdo principal
Toshiba Satellite L45-S7423 LCD Display Replacement
Stephen Sippel
Stephen Sippel e 3 outros colaboradores
Última atualização em June 14, 2023
15 - 20 minutos
Moderada
Guia do aluno destaque
The LCD display can be easily separated from the laptop body to allow for replacement if it is damaged or functioning improperly.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 2, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 3, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 3, imagem 2 %32
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, imagem 3 %32
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, imagem 3 %32
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, imagem 3 %32
    • Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
    • This screw is not designed to be completely removed, it is permanently fastened to the panel to avoid loss.
  7. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, imagem 3 %32
    • With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
  8. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 8, imagem 1 %32
    • Remove the yellow tape holding the black and the white wires in place.
  9. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, imagem 3 %32
    • Unwind the wires from the plastic tabs holding the wires in place.
  10. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 10, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 10, imagem 2 %32
    • Remove the screw holding the ground cable in place.
    • One 4.5 mm Phillips screw.
  11. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 11, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 11, imagem 2 %32
    • Disconnect the video cable connecting the display to the base of the laptop.
  12. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, imagem 3 %32
    • Pop off the laptop's hinge covers using a spudger tool.
    • Only a small amount of force is required. Excessive force may permanently damage the hinge covers.
  13. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 13, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 13, imagem 2 %32
    • Remove the two screws on the back side of the laptop holding the LCD display in place.
    • Two 8.5 mm Phillips screws.
  14. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 14, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 14, imagem 2 %32
    • Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
  15. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, imagem 1 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, imagem 2 %32 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, imagem 3 %32
    • Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
    • Be careful as you remove the display not to pull too hard on the cables as they pass through the opening.
Conclusão
3 outras pessoas executaram este guia.
Stephen Sippel
Membro desde: 04/16/13
194 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 21-54, Johann Spring 2013 Membro de Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,950
