Ir para o conteúdo principal
Toshiba Satellite L305D-S5950 RAM Replacement
Ricky Baker
Ricky Baker e 3 outros colaboradores
Última atualização em July 15, 2014
5 - 10 minutos
Fácil
Precisa de melhores imagens
Melhor Introdução
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L305D-S5950 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 2, imagem 2 %32
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 3, imagem 2 %32
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 RAM Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: passo 5, imagem 2 %32 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: passo 5, imagem 3 %32
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  6. Toshiba Satellite L305D-S5950 RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 6, imagem 2 %32
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  7. Toshiba Satellite L305D-S5950 RAM Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 7, imagem 2 %32
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  8. Toshiba Satellite L305D-S5950 RAM Replacement: passo 8, imagem 1 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 8, imagem 2 %32 Toshiba Satellite L305D-S5950 RAM Replacement: passo 8, imagem 3 %32
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
Conclusão
To reassemble your device, follow these instructions in reverse order. When placing the RAM chips in, push them down until the levers snap into place after inserting them into the slot.
Ricky Baker
Membro desde: 03/26/14
217 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-2, Benson Spring 2014 Membro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 437
