Toshiba Satellite L305D-S5950 Motherboard Cover Replacement
Introdução
Vá para o passo 1In order to take the motherboard cover off the keyboard needs to be removed.
O que você precisa
Ferramentas
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
