Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
10 - 20 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1If your CD/DVDs aren’t being read or even if your drive just makes too much noise with a disk in, this guide will assist you in removing the CD Drive from the computer entirely if it needs tweaking or replacement.
O que você precisa
The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
Quase terminado!
Conclusão
