Toshiba Satellite L305-S5946 Keyboard Replacement
Introdução
Vá para o passo 1Use this guide to replace the keyboard in your Toshiba Satellite L305-S5946. Unresponsive or sticky keys are good indicators that the keyboard should be replaced. You must remove the keyboard to access the base housing.
O que você precisa
Ferramentas
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Um comentário
Removing the battery as a precaution against short circuits while disconnecting/reconnecting the keyboard makes sense but I fail to understand why you say it's necessary to remove the HD & Memory as well; please expalin?
