Ir para o conteúdo principal
Toshiba Satellite L305-S5946 Hard Drive Replacement
Alec
Alec e 11 outros colaboradores
Última atualização em January 19, 2023
5 minutos
Fácil
Use this guide to replace or upgrade the hard drive in your Toshiba Satellite L305-S5946. If your hard drive is faulty or you want more storage, you should replace the hard drive.
O que você precisa
Ferramentas
  1. Toshiba Satellite L305-S5946 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 3, imagem 2 %32 Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 5, imagem 2 %32
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 6, imagem 2 %32 Toshiba Satellite L305-S5946 Hard Drive Replacement: passo 6, imagem 3 %32
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
Conclusão
4 outras pessoas executaram este guia.
Alec
Membro desde: 04/18/13
352 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-49, Amido Spring 2013 Membro de Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,198
