Ir para o conteúdo principal
Toshiba Satellite L305-S5875 RAM Replacement
Elliot Fiske
Elliot Fiske e 11 outros colaboradores
Última atualização em January 21, 2025
10 minutos
Moderada
Acidente de Marcação
Melhor Introdução
Installing additional RAM modules will increase the performance of your laptop, and is relatively easy to do.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Toshiba Satellite L305-S5875 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 3 %32
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
Conclusão
3 outras pessoas executaram este guia.
Elliot Fiske
Membro desde: 01/30/13
36 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-5, Maness Winter 2013 Membro de Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 6,840
