Ir para o conteúdo principal
Toshiba Satellite L305-S5875 Keyboard Replacement
Juan
Juan e 13 outros colaboradores
Última atualização em 10 de jan de 2025
15 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
If your Toshiba Satellite L305-S587 is not allowing you to type, use this guide in order to replace the keyboard. The keyboard allows you to enter information into the computer by pressing buttons, or keys. Things like physical damage, spills, or simply wear-and-tear may cause a keyboard to need to be replaced. No special skills are needed to replace the keyboard.
Before beginning this guide, shut down your computer. Inspect the keyboard to ensure that the cause of the malfunction is not debris stuck under or around the keys. Additionally, make sure that no parts of the keyboard are loose that may be causing it to malfunction.
O que você precisa
Ferramentas
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 5, imagem 2 %32
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 6, imagem 2 %32
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 7, imagem 1 %32
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Conclusão
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Juan
Membro desde: 01/11/13
109 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-5, Maness Winter 2013 Membro de Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 Membros
Autoria de 10 guias
1Comentário do guia
It's not so easy to do step 3.
Texas Chick - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Ao todo: 3,359
