Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Trackpad Replacement
Marvin Scott
Marvin Scott e 5 outros colaboradores
Última atualização em July 5, 2023
35 - 45 minutos
Moderada
Fotos de ação
Ferramentas incorretas
Precisa de melhores imagens
Precisa de mais images
Faltando Passos
This guide will provide you step-by-step instructions to successfully replace your Toshiba Satellite E45t-B4204 laptop's trackpad.
The trackpad is used as a built in cursor control function to navigate through on screen actions. If the trackpad is failing to move the cursor around the screen, then you will need to replace it in order to continue using the laptop.
For your safety, please ensure that the laptop is completely powered off, unplugged, and that you have grounded any static on you before continuing.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Toshiba Satellite E45t-B4204 Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Remove the 15 screws holding the back panel in place with the Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the battery from the laptop.
  3. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 3, imagem 1 %32
    • Ground yourself.
    • Failure to ground yourself may result in electric shock.
  4. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 4, imagem 1 %32 Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 4, imagem 2 %32
    • Remove speaker screws.
  5. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 5, imagem 1 %32
    • Unplug and remove the speakers using the spudger.
  6. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 6, imagem 1 %32
    • Remove the four screws holding the processor in place.
    • Remove the processor.
  7. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 7, imagem 1 %32
    • Remove the heatsink.
  8. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 8, imagem 1 %32
    • Remove the Wi-Fi card.
    • The Wi-Fi card is on the opposite side of the fan from the processor.
  9. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 9, imagem 1 %32
    • Remove keyboard screws.
  10. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 10, imagem 1 %32
    • Remove motherboard and attached components.
  11. Toshiba Satellite E45t-B4204 Trackpad Replacement: passo 11, imagem 1 %32
    • Remove trackpad.
Conclusão
Marvin Scott
Membro desde: 05/22/19
193 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G3, Wilson Summer 2019 Membro de IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 262
