Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Fan Replacement
Perla Ruiz
Perla Ruiz e 4 outros colaboradores
Última atualização em January 9, 2023
10 minutos
Moderada
Precisa de melhores imagens
This will be a quick guide on how to replace the fan of a Toshiba Satellite E45t-B4204. Replacing the fan will help prevent the device from overheating.
O que você precisa
Ferramentas
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: passo 1, imagem 2 %32 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: passo 1, imagem 3 %32
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 2, imagem 2 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: passo 3, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 3, imagem 2 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 3, imagem 3 %32
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: passo 4, imagem 1 %32
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 5, imagem 3 %32
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 6, imagem 2 %32
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite E45t-B4204 Fan Replacement: passo 7, imagem 3 %32
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
Conclusão
Perla Ruiz
Membro desde: 03/22/18
159 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 289
