Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement
Introdução
Vá para o passo 1If your laptop is always running slow and lagging, this guide will show you how to replace or upgrade your RAM card to solve this issue. This replacement only requires the screen portion of the laptop, so remove the keyboard before beginning.
O que você precisa
Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
Lift screen off of plastic cover to expose the internal components.
Remove the copper shield by removing the four Phillips screws that hold the shield in place.
Locate the metal cover that is protecting the RAM. It can easily be found in the corner (placed on top of the mother board).
Then remove the two pieces of tape towards the edge of the cover.
