Toshiba Satellite Click 2 L35W-B3204 Battery Replacement
Introdução
Vá para o passo 1If your laptop dies quickly after unplugging the power adapter, this guide will help you solve that problem by replacing the battery. This replacement only requires the screen portion of the laptop, so remove the keyboard before beginning.
O que você precisa
Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
Lift screen off of plastic cover to expose the internal components.
Remove the copper shield by removing the four Phillips screws that hold the shield in place.
