Ir para o conteúdo principal
Toshiba Satellite CL-15t-t-B1204X Battery Replacement
RJ Witschger
RJ Witschger e 3 outros colaboradores
Última atualização em December 30, 2022
10 - 15 minutos
Fácil
This guide will show you how to open up your device and remove the battery in the event that your device has power issues.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite CL-15t-t-B1204X Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 2, imagem 1 %32
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 3, imagem 1 %32
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 4, imagem 1 %32
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 5, imagem 1 %32
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 6, imagem 1 %32
    • Carefully unplug the battery from the device motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Duração total: 787
