Ir para o conteúdo principal
Toshiba Satellite C855D-S5109 Battery Replacement
Danny Meier
Danny Meier e 4 outros colaboradores
Última atualização em December 29, 2022
1 minuto
Muito fácil
If your Toshiba Satellite laptop (model C855D-S5109) is having trouble charging or holding a charge, use this guide to walk you through the steps to replace the battery.
Laptop batteries typically have a lifespan of 2 to 4 years and will gradually lose their ability to hold a charge over time. An older laptop battery will not be able to power the laptop as long as it used to, and it may even lose its ability to charge overall. Additionally, if a battery has been damaged, it may become very hot when it charges and it should be replaced.
No special tools or prior knowledge are required for this replacement. Before beginning this guide, make sure to power off you laptop completely and disconnect it from any power sources.
  1. Toshiba Satellite C855D-S5109 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C855D-S5109 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C855D-S5109 Battery Replacement: passo 2, imagem 2 %32
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite C855D-S5109 Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite C855D-S5109 Battery Replacement: passo 3, imagem 3 %32
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Danny Meier
Membro desde: 10/06/20
274 Reputação
Autoria de 1 guia
Equipe
Casper College, Team S1-G3, Lareau Fall 2020 Membro de Casper College, Team S1-G3, Lareau Fall 2020
CASC-LAREAU-F20S1G3
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 19
Duração total: 509
