Toshiba Satellite C855-S5115 Battery Replacement
Introdução
Ir para o passo 1This is a battery replacement guide for the Toshiba C855-S5115. The battery might need to be replaced if your laptop will no longer hold a charge or dies after a short amount of time. The battery will also need to be removed before replacing any other parts of the device.
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
