Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Introdução
Vá para o passo 1If your computer is not recognizing any CD/DVD in the drive, you may have a malfunctioning CD/DVD drive. This installation guide will help you through replacing the CD/DVD drive on the Toshiba Satellite C655D-S5084.
O que você precisa
Ferramentas
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
4 outras pessoas executaram este guia.
