Ir para o conteúdo principal
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Shelby Kunz
Shelby Kunz e 8 outros colaboradores
Última atualização em December 9, 2023
5 minutos
Fácil
If your computer is not recognizing any CD/DVD in the drive, you may have a malfunctioning CD/DVD drive. This installation guide will help you through replacing the CD/DVD drive on the Toshiba Satellite C655D-S5084.
O que você precisa
Ferramentas
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: passo 3, imagem 1 %32
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
Conclusão
4 outras pessoas executaram este guia.
Shelby Kunz
Membro desde: 04/19/13
69 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-20, Maness Spring 2013 Membro de Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 5,068
