Ir para o conteúdo principal
Toshiba Satellite C655-S5142 Keyboard Replacement
Alex Kozlowski
Alex Kozlowski e 5 outros colaboradores
Última atualização em February 16, 2025
3 - 5 minutos
Moderado
Pontos lista!
Precisa de melhores imagens
Melhor Introdução
Estudante em progresso
Introdução
Ir para o passo 1
If the keyboard of your Toshiba Satellite C655-S5142 isn't responding to attempts to type, this guide will help you to properly replace the previous components. If your keyboard is faulty, then it's likely that one key or multiple keys are no longer functioning as intended. Before you start the replacement, check to see if cleaning out the sensors by using a flathead screwdriver to gently pry up the keys, then dusting the keys using a dust blower or safe brush, before deciding to replace the keyboard itself. It may just need to be cleaned in order to function properly. Try to type a sentence or two using the faulty keys in order to make sure it's not resolved.
This is a sensitive part of the computer, so try to keep your area clean of food or dust while you work. If crumbs or dust get inside of the laptop's sensors, it may not function properly, even after replacing it.
Before beginning, ensure the laptop itself is turned off and disconnected from any external power source, such as a charger or hard drive.
O que você precisa
Ferramentas
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 2, imagem 2 %32
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 3, imagem 2 %32
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 4, imagem 2 %32
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Kozlowski
Membro desde: 03/21/19
244 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 415
