Toshiba Satellite C55D-B5206 Hard Drive Replacement
Introdução
Vá para o passo 1Hard disks may crash after long periods of use. In the event your hard drive crashes, or you simply desire to upgrade to a solid state drive. Replacing the hard drive is moderately easy and requires a few simple steps.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
7 outras pessoas executaram este guia.
2 comentários
Thanks.. Really helped out..
