Toshiba Satellite C55D-A5201 RAM Replacement
Introdução
Vá para o passo 1Remove the RAM module with this guide. Reverse the steps to install a new one to allow for more laptop storage.
O que você precisa
Ferramentas
Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
With the Phillips #0 screwdriver, unscrew the 4.6mm screw on the left side of the "L"-shaped covering.
3 outras pessoas executaram este guia.
