Toshiba Satellite C55-B5200 Keyboard Replacement
Introdução
Ir para o passo 1Standard Keyboard with 10-key and touchpad with multi-touch control
O que você precisa
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
