Ir para o conteúdo principal
Toshiba Satellite C55-A5310 Fan Replacement
Robin
Robin e 3 outros colaboradores
Última atualização em May 7, 2024
10 minutos
Moderada
Melhor Introdução
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, imagem 3 %32
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: passo 2, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: passo 2, imagem 2 %32
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 4, imagem 2 %32
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: passo 6, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement, Fan: passo 6, imagem 2 %32
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 8, imagem 2 %32
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: passo 10, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 10, imagem 2 %32
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: passo 11, imagem 1 %32
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: passo 12, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 12, imagem 2 %32
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: passo 13, imagem 1 %32
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: passo 14, imagem 1 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 14, imagem 2 %32 Toshiba Satellite C55-A5310 Fan Replacement: passo 14, imagem 3 %32
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: passo 15, imagem 1 %32
    • Lift from corresponding sides of the fan and it'll pop right out.
Conclusão
Robin
Membro desde: 02/08/18
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 602
