Ir para o conteúdo principal
Toshiba Satellite C55-A5286 Optical Drive Replacement
Nicole Zellers
Nicole Zellers e 2 outros colaboradores
Última atualização em July 14, 2023
10 minutos
Moderado
Introdução
Ir para o passo 1
This guide will show you how to remove or replace the optical disc drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
O que você precisa
Peças
Ferramentas
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 2, imagem 2 %32
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 3, imagem 1 %32
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 4, imagem 1 %32
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 5, imagem 2 %32
    • Carefully slide the optical drive out of its place in the laptop.
Conclusão
Nicole Zellers
Membro desde: 11/06/18
265 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Hovde Fall 2018 Membro de IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Membros
Autoria de 9 guias
Um comentário
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 340
