Toshiba Satellite C55-A5100 Keyboard Replacement
Introdução
Ir para o passo 1This guide will show you how to replace the keyboard on your Toshiba Satellite C55-A5100.
O que você precisa
Ferramentas
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
Uma outra pessoa concluiu este guia.
