Ir para o conteúdo principal
Toshiba Satellite A660-ST3NX2X Screen Replacement
Megan Murrell
Megan Murrell e 4 outros colaboradores
Última atualização em May 7, 2024
5 - 15 minutos
Moderada
Precisa de melhores imagens
This replacement guide is to walk you through a screen replacement on your Toshiba Satellite A660-ST3NX2X. Before starting this replacement, make sure you have a replacement screen that is made for this computer. Also, make sure the computer is powered off and completely shut down before completing this replacement.
O que você precisa
  1. Toshiba Satellite A660-ST3NX2X Screen Replacement, Battery: passo 1, imagem 1 %32
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 2, imagem 2 %32
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 3, imagem 2 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 3, imagem 3 %32
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: passo 4, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Unplug all devices and power down the computer completely.
    • Peel back all four circular stickers that are located at each corner of the computer frame.
    • A pair of fine point tweezers was used to complete this.
  5. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 5, imagem 1 %32
    • Unscrew all four 5mm screws located underneath the stickers in each corner of the computer frame.
    • The computer frame should become more loose after the screws are removed.
  6. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 6, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 6, imagem 2 %32
    • Pry the frame of the screen away from the computer.
    • A prying tool was used by inserting it in the crack between the frame and the screen and running it along the edges of the frame.
  7. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 7, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 7, imagem 2 %32
    • Unscrew the three black 4mm JIS screws on each side of the metal frame that is still attached to the side of the screen.
    • Only two screws are shown in the image.
    • The metal frame will completely separate from the computer screen.
  8. Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 8, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 8, imagem 2 %32 Toshiba Satellite A660-ST3NX2X Screen Replacement: passo 8, imagem 3 %32
    • Position the screen in a way that the aluminum backing is exposed.
    • Peel off the metal-like attachment from the back of the screen.
Conclusão
Megan Murrell
Membro desde: 03/20/17
322 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team S8-G1, Bennett Spring 2017 Membro de Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 536
