Ir para o conteúdo principal
Toshiba Satellite A210 Motherboard Replacement
Devin
Devin e 11 outros colaboradores
Última atualização em January 21, 2025
Nenhuma estimativa
Difícil
Acidente de Marcação
Precisa de mais images
Despedaçar
Faltando detalhes
Before attempting this guide, please have all required materials and tools. This guide is a long process and requires your full attention in order to properly replace it. When doing each step be careful and follow each step as listed.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite A210 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Motherboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 2, imagem 2 %32
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Motherboard Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement, RAM: passo 3, imagem 2 %32
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Motherboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 4, imagem 3 %32
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, imagem 3 %32
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
  6. Toshiba Satellite A210 Motherboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  7. Toshiba Satellite A210 Motherboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 7, imagem 3 %32
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  8. Toshiba Satellite A210 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  9. Toshiba Satellite A210 Motherboard Replacement: passo 9, imagem 1 %32
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
  10. Toshiba Satellite A210 Motherboard Replacement, Fan: passo 10, imagem 1 %32
    • Close the laptop and flip it over.
    • Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
    • Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
    • Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
  11. Toshiba Satellite A210 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 11, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 11, imagem 3 %32
    • Flip the laptop over and open it so that the screen is facing you.
    • Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
    • Unscrew the 2 screws in each hinge with a PH1 screwdriver.
    • The display is no longer connected to the laptop and could fall. Be careful not to drop it during the next steps.
  12. Toshiba Satellite A210 Motherboard Replacement: passo 12, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 12, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 12, imagem 3 %32
    • Unfasten the connectors from the highlighted locations.
    • Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
    • Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
    • Unscrew the screw indicated by the yellow circle.
  13. Toshiba Satellite A210 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 13, imagem 2 %32
    • Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
  14. Toshiba Satellite A210 Motherboard Replacement: passo 14, imagem 1 %32
    • The LCD screen can now be removed from the laptop.
    • Lift the upper plastic casing and remove it from the lower half of the laptop.
  15. Toshiba Satellite A210 Motherboard Replacement: passo 15, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 15, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 15, imagem 3 %32
    • Unfasten the two connections shown.
    • Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
    • Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
    • Do not remove the metal fan housing. It is taped to a metal heat-sink and should not be removed.
  16. Toshiba Satellite A210 Motherboard Replacement, Motherboard: passo 16, imagem 1 %32
    • First, remove the one screw with a PH1 screwdriver.
    • Next, remove the black connector marked by the yellow box.
  17. Toshiba Satellite A210 Motherboard Replacement: passo 17, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 17, imagem 2 %32
    • Gently pull the the small white ribbon cable from its housing on the motherboard.
    • Locate and unfasten the small white clip from the motherboard near the bottom right.
  18. Toshiba Satellite A210 Motherboard Replacement: passo 18, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 18, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 18, imagem 3 %32
    • Disconnect the two white fasteners that connect the speakers to the motherboard.
  19. Toshiba Satellite A210 Motherboard Replacement: passo 19, imagem 1 %32 Toshiba Satellite A210 Motherboard Replacement: passo 19, imagem 2 %32 Toshiba Satellite A210 Motherboard Replacement: passo 19, imagem 3 %32
    • Gently slide the plastic opening tool underneath and around the motherboard.
    • Do not force the motherboard out. If the motherboard breaks, it is not repairable. You will have to buy a new one.
    • After the motherboard is free of the plastic casing, do not pull it all the way out. There is still a connector on the underside of it.
    • Remove the connector on the underside using your fingers.
Conclusão
8 outras pessoas executaram este guia.
Devin
Membro desde: 04/11/13
66 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-5, Regan Spring 2013 Membro de Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 55
Duração total: 8,149
