Toshiba Satellite A105-S4011 RAM Replacement
Introdução
Ir para o passo 1This guide will show you how to remove the current RAM module from this laptop and how to re-install a RAM module. Accessing the RAM in this computer is straightforward and requires minimal minimal dis-assembly.
O que você precisa
Peças
Ferramentas
Exibir mais…
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
Uma outra pessoa concluiu este guia.
