Ir para o conteúdo principal
Toshiba Satellite A105-S4011 Hard Disk Drive Replacement
Connor Russell
Connor Russell e 7 outros colaboradores
Última atualização em May 7, 2023
5 minutos
Fácil
Fotos de ação
Ferramentas incorretas
Precisa de mais images
This guide will show you how to remove the current Hard Drive and how to replace it. Accessing the Hard Drive in this computer is straightforward and only requires minimal dis-assembly with a screwdriver. Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
O que você precisa
Ferramentas
  1. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: passo 2, imagem 2 %32
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 1 %32
    • Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
    • You may want to ground yourself before attempting to touch any components. This means touching a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    • Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
  4. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: passo 4, imagem 1 %32
    • Once the screw is completely removed, pull back the plastic cover carefully.
    • If you are having trouble removing the cover, a plastic removal tool may be used.
  5. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard disk by gently applying pressure with your thumb while sliding the hard disk to the left.
    • If you do not ground yourself, you run the risk of damaging your hard disk.
Conclusão
4 outras pessoas executaram este guia.
Connor Russell
Membro desde: 04/18/13
49 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-14, Maness Spring 2013 Membro de Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 1,856
