Ir para o conteúdo principal
Toshiba Satellite 2435-S255 Heat Sink Replacement
Jonathan Lancey
Jonathan Lancey e 3 outros colaboradores
Última atualização em May 7, 2024
10 - 15 minutos
Moderada
Remove the Battery. Whenever tinkering with electronics, always turn them off and remove all sources of power if possible; otherwise you could hurt yourself or damage your machine irreparably.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite 2435-S255 Heat Sink Replacement, Removing the Latch: passo 1, imagem 1 %32 Toshiba Satellite 2435-S255 Heat Sink Replacement, Removing the Latch: passo 1, imagem 2 %32
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Heat Sink Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
  3. Toshiba Satellite 2435-S255 Heat Sink Replacement, Unscrew and Remove the Cover: passo 3, imagem 1 %32
    • Using a T6 screwdriver, unscrew the two indicated 4mm screws to remove the panel.
    • After that, simply lift and pull out the cover panel.
  4. Toshiba Satellite 2435-S255 Heat Sink Replacement, Remove the Heat Sink Brackets: passo 4, imagem 1 %32 Toshiba Satellite 2435-S255 Heat Sink Replacement, Remove the Heat Sink Brackets: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • This step can be kind of tricky. Using a PH00 screwdriver, remove the eight indicated screws. The screws in the four corners are 5mm while the four screws on the left and right sides are 3mm.
    • It doesn’t matter which order you unscrew them when removing the heat sink.
    • If you’re removing one of the top or bottom (red) ones for that side last, make sure to use a pair of tweezers to hold the other end so that the bracket doesn’t drop into the laptop.
  5. Toshiba Satellite 2435-S255 Heat Sink Replacement, Pull Out the Heat Sink: passo 5, imagem 1 %32 Toshiba Satellite 2435-S255 Heat Sink Replacement, Pull Out the Heat Sink: passo 5, imagem 2 %32
    • To remove the heat sink, pull it away from the fan and up.
    • You’ll probably need to wiggle it around a bit, but it should come out easily.
    • Be careful, however; there will be thermal paste in the middle of the bottom, where it connected to the CPU. If you’re putting in a new heat sink, I recommend cleaning off the CPU and applying a new layer of thermal paste.
    • Done! The heat sink is out. Check the conclusion for a little information on putting it back in.
Conclusão
When re-installing the heat sink, start with one of the top/bottom screws for the bracket, then do the middle two, and then the last top/bottom one. For the last screw, push down on that end of the bracket so the screwholes line up. Otherwise, follow these instructions in reverse order.
Equipe
UMass Dartmouth, Team 1-5, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-5, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G5
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 460
