Ir para o conteúdo principal
Toshiba Satellite 1415-S105 Keyboard Replacement
Kiril Lange
Kiril Lange e um outro colaborador
Última atualização em April 29, 2023
5 - 10 minutos
Moderada
Use this guide to replace the keyboard on your Toshiba Satellite.
O que você precisa
Ferramentas
  1. Toshiba Satellite 1415-S105 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 2, imagem 1 %32
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 3, imagem 2 %32
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 4, imagem 2 %32
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32 Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, imagem 3 %32
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 6, imagem 2 %32
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 7, imagem 2 %32
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, imagem 2 %32 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, imagem 3 %32
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
Conclusão
Kiril Lange
Membro desde: 09/22/14
943 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 3-2, Brown Fall 2014 Membro de USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 332
