Toshiba Qosmio X775-3DV80 Fan Replacement
20 minutos
Moderada
Faltando Passos
Melhor Introdução
O que você precisa
Locate the optical drive retaining screw on the underside of the laptop.
Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
Quase terminado!
Conclusão
