Ir para o conteúdo principal
Toshiba Portege R835-P56X Speaker Replacement
Anay Sanchez
Anay Sanchez e 2 outros colaboradores
Última atualização em May 7, 2024
Nenhuma estimativa
Moderada
Precisa de melhores imagens
With this guide you will be able to replace the speakers of your Toshiba Portege R835-P56X.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Portege R835-P56X Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Turn laptop with the back cover facing up .
    • Make sure the laptop is unplugged and powered off before beginning.
  2. Toshiba Portege R835-P56X Speaker Replacement: passo 2, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 2, imagem 2 %32
    • Unlock the clips by pulling towards the unlock.
  3. Toshiba Portege R835-P56X Speaker Replacement: passo 3, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 3, imagem 2 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 3, imagem 3 %32
    • Holding the unlock clips push the battery away from the laptop.
  4. Toshiba Portege R835-P56X Speaker Replacement: passo 4, imagem 1 %32
    • Remove the screws from the back of the laptop
    • you should have removed 18 screws, make sure to keep these in a safe place as you will need them for reassembly.
  5. Toshiba Portege R835-P56X Speaker Replacement: passo 5, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 5, imagem 2 %32
    • Using the blue prying plastic tool remove the back cover.
  6. Toshiba Portege R835-P56X Speaker Replacement: passo 6, imagem 1 %32
    • Remove the screws from the fan and side ports
  7. Toshiba Portege R835-P56X Speaker Replacement: passo 7, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 7, imagem 2 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 7, imagem 3 %32
    • Remove the white and orange cables attached by pulling out the cables
  8. Toshiba Portege R835-P56X Speaker Replacement: passo 8, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 8, imagem 2 %32
    • locate the speakers
    • Gently lift the motherboard to release the speaker cables
  9. Toshiba Portege R835-P56X Speaker Replacement: passo 9, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, gently remove the tape being used to hold down the speaker cables.
  10. Toshiba Portege R835-P56X Speaker Replacement: passo 10, imagem 1 %32 Toshiba Portege R835-P56X Speaker Replacement: passo 10, imagem 2 %32
    • Once the cable had been released you have successfully removed the speakers!
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 439
