Ir para o conteúdo principal
Toshiba Portege R835-P56X Screen Replacement
Anay Sanchez
Anay Sanchez e 3 outros colaboradores
Última atualização em May 7, 2024
10 minutos
Moderada
Precisa de melhores imagens
In this guide we will remove the screen from a Toshiba Portege R835-P56X
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Portege R835-P56X Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop with the battery facing up.
    • Make sure the laptop is powered off and unplugged.
  2. Toshiba Portege R835-P56X Screen Replacement: passo 2, imagem 1 %32 Toshiba Portege R835-P56X Screen Replacement: passo 2, imagem 2 %32
    • Unlock the clips by pulling towards the open lock.
  3. Toshiba Portege R835-P56X Screen Replacement: passo 3, imagem 1 %32 Toshiba Portege R835-P56X Screen Replacement: passo 3, imagem 2 %32 Toshiba Portege R835-P56X Screen Replacement: passo 3, imagem 3 %32
    • Hold the unlock clip while pulling the battery away from the laptop.
  4. Toshiba Portege R835-P56X Screen Replacement, Screen: passo 4, imagem 1 %32 Toshiba Portege R835-P56X Screen Replacement, Screen: passo 4, imagem 2 %32 Toshiba Portege R835-P56X Screen Replacement, Screen: passo 4, imagem 3 %32
    • Use the screwdriver to unscrew 18 screws.
    • Remove the back cover of the laptop.
  5. Toshiba Portege R835-P56X Screen Replacement: passo 5, imagem 1 %32
    • Remove the screw from the metal hinges in the top corners of the laptop as shown in the picture.
  6. Toshiba Portege R835-P56X Screen Replacement: passo 6, imagem 1 %32
    • Disconnect the white plug with red and black wires located on the right-most upper corner with the chrome hinges pointed farthest away from you.
  7. Toshiba Portege R835-P56X Screen Replacement: passo 7, imagem 1 %32 Toshiba Portege R835-P56X Screen Replacement: passo 7, imagem 2 %32
    • Remove the chrome hinges using the blue prying tool. The hinges should pop right off without must effort.
  8. Toshiba Portege R835-P56X Screen Replacement: passo 8, imagem 1 %32
    • Remove the screws located underneath the hinges.
  9. Toshiba Portege R835-P56X Screen Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the plastic caps from the top edge of the laptop screen, located near the front-facing camera. All but the cap closest to the camera should be removed.
  10. Toshiba Portege R835-P56X Screen Replacement: passo 10, imagem 1 %32
    • Remove the screws located underneath the plastic caps.
  11. Toshiba Portege R835-P56X Screen Replacement: passo 11, imagem 1 %32
    • Snap the laptop screen casing off.
  12. Toshiba Portege R835-P56X Screen Replacement: passo 12, imagem 1 %32 Toshiba Portege R835-P56X Screen Replacement: passo 12, imagem 2 %32
    • Disconnect the grey mesh wire from underneath the unattached laptop screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 674
