Ir para o conteúdo principal
Toshiba Portege R205-S209 Keyboard Replacement
Leah Catania
Leah Catania
Última atualização em April 8, 2023
15 minutos
Moderada
Guia colaborativo
Replacing the keyboard on your laptop may seem daunting at first, but it is actually a relatively simple component to remove and replace. With the use of a few tools and about fifteen minutes of work, you can have a new keyboard up and running for your laptop.
O que você precisa
Ferramentas
  1. Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
  2. Toshiba Portege R205-S209 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the locking mechanism to the right and hold.
  3. Toshiba Portege R205-S209 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 3, imagem 2 %32
    • While holding the locking mechanism to the right, insert your finger into the tab and lift up.
  4. Toshiba Portege R205-S209 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove battery by lifting upward.
  5. Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
  6. Toshiba Portege R205-S209 Keyboard Replacement: passo 6, imagem 1 %32
    • Flip the laptop over and open the display.
  7. Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the plastic casing above the keyboard with the plastic opening tool. Start at the edges of the plastic casing and move toward the middle.
  8. Toshiba Portege R205-S209 Keyboard Replacement: passo 8, imagem 1 %32
    • Lift up and remove the plastic casing.
  9. Toshiba Portege R205-S209 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 9, imagem 2 %32
    • Remove the 4mm Phillips head screws at the top of the keyboard at both ends, using the Phillips head #00 screwdriver.
  10. Toshiba Portege R205-S209 Keyboard Replacement: passo 10, imagem 1 %32
    • Lift up the keyboard, but do not remove it completely.
    • The keyboard is still attached to the computer, so be very careful when lifting it up.
  11. Toshiba Portege R205-S209 Keyboard Replacement: passo 11, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 11, imagem 2 %32
    • Gently pull the ribbon toward the screen until it slides out of the connecting point.
    • Remove keyboard.
Conclusão
Leah Catania
Membro desde: 10/12/15
113 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 12
Duração total: 365
