Toshiba Portege M400 Keyboard Replacement
Introdução
Vá para o passo 1In this guide, you will learn how to disassemble the broken/damaged keyboard from the rest of the laptop as well as how to replace it. This guide will also teach you what the proper and necessary tools are for this repair.
O que você precisa
Remove the front face plate with a plastic opening tool.
Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
Uma outra pessoa concluiu este guia.
