Ir para o conteúdo principal
Toshiba NB255-N250 Memory Replacement
Charles Myrick
Charles Myrick e 2 outros colaboradores
Última atualização em February 25, 2023
1 - 10 minutos
Fácil
Guia colaborativo
O que você precisa
Ferramentas
  1. Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: passo 1, imagem 1 %32 Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: passo 1, imagem 2 %32
    • Before starting any repairs, make sure to power off your device.
    • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
  2. Toshiba NB255-N250 Memory Replacement, Remove the Battery: passo 2, imagem 1 %32 Toshiba NB255-N250 Memory Replacement, Remove the Battery: passo 2, imagem 2 %32 Toshiba NB255-N250 Memory Replacement, Remove the Battery: passo 2, imagem 3 %32
    • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
  3. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel Screw: passo 3, imagem 1 %32
    • Remove the PH1 screw from the memory access panel.
    • Unlike many other access cover screws on laptops, this screw is not captive.
  4. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel: passo 4, imagem 1 %32
    • Use a Metal Spudger or other opening tool to remove the memory access panel.
  5. Toshiba NB255-N250 Memory Replacement, Remove Old Memory: passo 5, imagem 1 %32 Toshiba NB255-N250 Memory Replacement, Remove Old Memory: passo 5, imagem 2 %32
    • Remove the memory by moving the tabs on the left and right away from the ram.
    • When fully opened, the memory will pop up at a 45 degree angle. Pull the memory straight out by the sides and away from the system.
Conclusão
Charles Myrick
Membro desde: 10/19/18
270 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 475
