Ir para o conteúdo principal
Toshiba Encore Mini Rear-Facing Camera Replacement
Anthony Bivens
Anthony Bivens e 3 outros colaboradores
Última atualização em May 7, 2024
20 - 30 minutos
Moderado
Faltando Passos
Introdução
Ir para o passo 1
The Toshiba Encore Mini has a rear-facing camera which is attached to the motherboard and requires battery removal for replacement. Therefore be advised to backup any data to external storage before beginning. As well as obtain a system to organize small screws and hand tools.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Encore Mini Rear-Facing Camera Replacement, Battery: passo 1, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement, Battery: passo 1, imagem 2 %32
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 2, imagem 1 %32
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 3, imagem 1 %32
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 4, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Rear-Facing Camera Replacement, Front-Facing Camera: passo 6, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement, Front-Facing Camera: passo 6, imagem 2 %32 Toshiba Encore Mini Rear-Facing Camera Replacement, Front-Facing Camera: passo 6, imagem 3 %32
    • The audio module must be removed to replace the front-facing camera.
    • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
    • Gently remove red/black wire strands from the clips holding them to the back of the screen.
  7. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 7, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 7, imagem 2 %32
    • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
    • Adhesive on the bottom of the speaker module may make it difficult to remove.
    • Set the audio module and attached wire aside.
  8. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 8, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 8, imagem 2 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 8, imagem 3 %32
    • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
    • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
  9. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 9, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 9, imagem 2 %32
    • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
    • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
  10. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 10, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 10, imagem 2 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 10, imagem 3 %32
    • Damaging this ribbon will permanently disable your device!
    • Using needle-nose tweezers, carefully flip up the dark gray cover.
    • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
  11. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 11, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 11, imagem 2 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 11, imagem 3 %32
    • Using a Phillips 000 screwdriver, remove the screws holding components together.
    • Remove four 4.2 mm Phillips screws.
    • Remove one 3mm Phillips screw.
  12. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 12, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 12, imagem 2 %32
    • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
    • The motherboard may resist as you try to lift it --this is normal.
  13. Toshiba Encore Mini Rear-Facing Camera Replacement: passo 13, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement: passo 13, imagem 2 %32
    • The front-facing camera may dislodge freely when removing the motherboard.
    • If camera has not already "popped" off the motherboard, use needle-nose tweezers to gently grasp the camera and remove from motherboard.
  14. Toshiba Encore Mini Rear-Facing Camera Replacement, Rear-Facing Camera: passo 14, imagem 1 %32 Toshiba Encore Mini Rear-Facing Camera Replacement, Rear-Facing Camera: passo 14, imagem 2 %32
    • Remove yellow tape.
    • Use tweezers to pull on the camera housing until it is free of the motherboard.
Conclusão
Anthony Bivens
Membro desde: 03/04/17
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S5-G5, Wilson Spring 2017 Membro de IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 164
