Ir para o conteúdo principal
Toshiba Dynabook AX 53D Touchpad Replacement
Christopher
Christopher e 3 outros colaboradores
Última atualização em February 19, 2023
30 minutos
Moderada
In this guide users will replace the touchpad in the Toshiba Dynabook AX 53D. This process includes removing the top panel screws under the laptop, removing the media bezel, unscrewing the keyboard, popping the top panel off, and disconnecting the touchpad.
O que você precisa
Ferramentas
  1. Toshiba Dynabook AX 53D Touchpad Replacement, Battery: passo 1, imagem 1 %32
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Touchpad Replacement: passo 2, imagem 1 %32
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Touchpad Replacement, Keyboard: passo 3, imagem 1 %32
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Touchpad Replacement: passo 4, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 4, imagem 2 %32
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Touchpad Replacement: passo 5, imagem 1 %32
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Touchpad Replacement: passo 6, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 6, imagem 2 %32
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
  7. Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: passo 7, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: passo 7, imagem 2 %32
    • Detach the white plastic end of the braided LCD cable.
  8. Toshiba Dynabook AX 53D Touchpad Replacement: passo 8, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 8, imagem 2 %32
    • Using the flat metal spatula tool, detach the thin white and black wires from their pop connectors.
  9. Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, imagem 2 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, imagem 3 %32
    • Using the #J1 Phillips Screwdriver, remove the four 7.6 mm screws that secure the monitor to rest of laptop.
    • The monitor can now be gently removed by lifting upwards.
  10. Toshiba Dynabook AX 53D Touchpad Replacement: passo 10, imagem 1 %32
    • Run the plastic opening tool along the crease between the top touchpad bezel and bottom section of laptop.
  11. Toshiba Dynabook AX 53D Touchpad Replacement: passo 11, imagem 1 %32 Toshiba Dynabook AX 53D Touchpad Replacement: passo 11, imagem 2 %32
    • Gently detach the touchpad bezel.
    • The ribbon cable may break if removed roughly.
    • Gently remove the white ribbon cable.
  12. Toshiba Dynabook AX 53D Touchpad Replacement: passo 12, imagem 1 %32
    • Remove the six 3.7 mm #J1 screws holding the touchpad in place.
  13. Toshiba Dynabook AX 53D Touchpad Replacement: passo 13, imagem 1 %32
    • Gently pull the ribbon cable to disconnect it from the touchpad.
  14. Toshiba Dynabook AX 53D Touchpad Replacement: passo 14, imagem 1 %32
    • Carefully pry up the touchpad with a plastic opening tool.
  15. Toshiba Dynabook AX 53D Touchpad Replacement: passo 15, imagem 1 %32
    • The touchpad has been removed.
Conclusão
Christopher
Membro desde: 03/20/17
525 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 462
