Ir para o conteúdo principal
Toshiba Chromebook 2 Touchpad Replacement
Haley Hattendorf
Haley Hattendorf e 3 outros colaboradores
Última atualização em December 22, 2016
8 minutos
Moderado
Introdução
Ir para o passo 1
A touchpad is extremely important in the use of laptops. The touchpad can often cause the cursor to not move in the right direction, or not at all. When these are continual problems, the best solution is to replace the faulty touchpad with a new one.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Touchpad Replacement: passo 2, imagem 1 %32
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Touchpad Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 3, imagem 2 %32
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Touchpad Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 4, imagem 2 %32
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: passo 6, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement, Battery: passo 6, imagem 2 %32
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Touchpad Replacement: passo 7, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 7, imagem 2 %32
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Touchpad Replacement: passo 8, imagem 1 %32
    • Remove the battery by gently pulling up on the bottom corners.
    Thank you for the step by step guide!
    yoena lopez - Responder
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: passo 9, imagem 1 %32
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 2 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 3 %32
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Touchpad Replacement: passo 11, imagem 1 %32
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: passo 12, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: passo 12, imagem 2 %32
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
  13. Toshiba Chromebook 2 Touchpad Replacement: passo 13, imagem 1 %32
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
  14. Toshiba Chromebook 2 Touchpad Replacement: passo 14, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 14, imagem 2 %32
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
  15. Toshiba Chromebook 2 Touchpad Replacement: passo 15, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 15, imagem 2 %32
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
  16. Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 2 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 3 %32
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
  17. Toshiba Chromebook 2 Touchpad Replacement: passo 17, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 17, imagem 2 %32
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
Conclusão
4 outras pessoas executaram este guia.
Haley Hattendorf
Membro desde: 10/06/16
598 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-4, Livingston Fall 2016 Membro de Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Membros
Autoria de 11 guias
2 comentários
Thanks for this guide! Worked perfectly.
Mathias Maes - Responder
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 24
Ao todo: 1,885
