Ir para o conteúdo principal
Tofu65 Keyboard PCB Replacement
Daniel Payan
Daniel Payan e 2 outros colaboradores
Última atualização em 20 de jun de 2024
30 minutos - 1 hora
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
This guide demonstrates how to replace a malfunctioning keyboard PCB from a Tofu65 keyboard with a new hot-swap PCB. The PCB is the backbone of the keyboard and ensures connection or communication between the keyboard and other the components in the keyboard. It is essential to have in good condition so you don't have to replace the entire device. No prior experience is required.
Before you begin the repair, disconnect the power cord.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: passo 1, imagem 1 %32
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: passo 2, imagem 1 %32
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: passo 3, imagem 1 %32
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: passo 4, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 4, imagem 2 %32
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: passo 5, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 5, imagem 2 %32
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: passo 6, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 6, imagem 2 %32 Tofu65 Keyboard PCB Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: passo 7, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 7, imagem 2 %32
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: passo 8, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 8, imagem 2 %32
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: passo 9, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 9, imagem 2 %32 Tofu65 Keyboard PCB Replacement: passo 9, imagem 3 %32
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: passo 10, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 10, imagem 2 %32
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Daniel Payan
Membro desde: 03/05/24
202 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 557
