Ir para o conteúdo principal
Thomas Kinkade Wonderland Express Disassembly
Juergen Klute
Juergen Klute e 3 outros colaboradores
Última atualização em January 3, 2025
1 - 3 horas
Moderada
Guia colaborativo
Faltando detalhes
This guide will show you how to disassemble the device in order to solve the problems with train movement and lights.
O que você precisa
Ferramentas
  1. Thomas Kinkade Wonderland Express Disassembly, Wonderland Express: passo 1, imagem 1 %32 Thomas Kinkade Wonderland Express Disassembly, Wonderland Express: passo 1, imagem 2 %32
    • The very top part is glued to the next one below. It has to be carefully cut of or using a very little saw to get it of the part below. Disconnect the connector for the lights and unscrew the four nuts.
  2. Thomas Kinkade Wonderland Express Disassembly: passo 2, imagem 1 %32 Thomas Kinkade Wonderland Express Disassembly: passo 2, imagem 2 %32
    • Disconnect the connector for the lights and unscrew the four nuts. The plastic part holding the train and the gear can be removed. Work one level down after the other. After removing the nuts the levels are glued to the next base so the glue needs to be cut or removed as well.
  3. Thomas Kinkade Wonderland Express Disassembly: passo 3, imagem 1 %32
    • View at the very base level with the motor on the left and the gearbox open.
    • Found the problem to be a stuck gearbox which prevented the trains from moving
    • Found problems on the PC board as well. Two transistors were overheated and not working any longer due to blocked gear box.
    • Assemble in reverse order
Conclusão
11 outras pessoas executaram este guia.
Juergen Klute
Membro desde: 02/02/14
645 Reputação
Autoria de 2 guias
Equipe
JKL Consulting Membro de JKL Consulting
Business
1 Membro
Autoria de 4 guias
43 comentários
I have the same Hawthorne Village tree and when purchased it played music with the lights & train in motion; it no longer plays the music when lit with trains in motion. I noticed no music playing on the video on this site. Looking to repair this problem.
Fred Lang - Responder
My Christmas train tree does not run nor is there music nor is there lights you put batteries in and nothing happens. I need help repairing it or someplace to send it to have it repaired the Hawthorne company no longer wants to take responsibility for and yet they continue to sell it
queensgiftsamf - Responder
If nothing at all happens once you put batteries in then I assume that there is a broken connection from batteries to the PC board. The other possible cause is that the PC board itself is the problem. In any case you need to dismantle the tree according to the description because the electronic board is at the very bottom. If you can, check the voltage and the transistors on the PC board.
Juergen Klute - Responder
Hi,
Is there anyway to stop Santa from squeaking?
Thanks,
Noreen Snead
nmasnead@gmail.com
Noreen Snead - Responder
I am trying to put the Santa and reindeer on the top of the tree. Could anyone help me with this assemble?
VALERIE BLOUNT - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 77
Duração total: 19,496
